If the rear signal light bulb on your 2016-2022 Honda HR-V dies or burns out, use this guide to replace those light bulbs.
Rear turn signal lights are light bulbs that communicate the driver's intent to change lanes, so it is essential to change these lightbulbs if they stop functioning. The specific rear turn signal light bulb necessary for this vehicle model is 21 W (Amber).
This guide will show you how to replace the left rear signal light bulb, but the process is the same on both the left and right rear signal light bulbs.
Before starting, make sure that you turn off your vehicle and engage the parking brake.
Press the tailgate release button and lift open the rear hatch.
Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
Pull apart the light bulb from its socket.
Slide the light assembly into the raised white plastic attached to the vehicle.
Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
Excelente informações
