2020 Ford F150 3.5L Cold Air Intake Replacement
  1. 2020 Ford F150 3.5L Cold Air Intake Replacement, ROUSH Cold Air Intake 3.5L: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement, ROUSH Cold Air Intake 3.5L: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement, ROUSH Cold Air Intake 3.5L: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, make sure the truck is turned off and in park.
    • Open the hood and ensure it is securely propped up.
    • Loosen the clamps on the factory air intake using a flathead screwdriver.
  2. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the clips from the stock air suction hose
  3. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cable connector.
  4. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Connect the new dual air hoses to the stock air hose and tighten them using a flathead screwdriver.
    • Attach the stock air scoop to the casing of the new intake using a 6mm socket and bolt.
  5. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the stock 12mm screw using a socket, then place the grommet on before screwing it back in. Leave enough space for the new air intake casing to fit securely into the grommet.
  6. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bolt in the two 8mm bolts that secure the new air filter.
    • Once secured, fit the new air filter into place.
  7. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the clips into the two fittings in the engine bay.
    • Connect the air hose and tighten it securely.
    • The new intake casing should now fit into the air hose and engine bay without any extra parts.
  8. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the clips back into the stock air shovel intake
    • Reconnect the stock wiring to the new air hose so the truck’s electrical system can detect emissions and any signals that may trigger alerts.
    • If desired, apply the decorative "Roush" sticker to the air intake casing cover, which represents the brand of the new intake filter.
  9. 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2020 Ford F150 3.5L Cold Air Intake Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After attaching the sticker, place the casing on for appearance purposes.
    • Bolt in the 6 T20 Torx screws to secure the casing.
    • Once all 6 T20 Torx bolts are tightened, you've successfully installed your brand new cold air intake, which improves airflow and boosts both performance and efficiency.
Deklin Bryant
crwdns2935283:009/28/24crwdne2935283:0
190 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 2-2, Kapoor Fall 2024 crwdns2935289:0Austin Community College, Team 2-2, Kapoor Fall 2024crwdne2935289:0
AUSTINCC-KAPOOR-F24S2G2
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 266
