2018 Toyota Corolla LE Battery Replacement
  1. 2018 Toyota Corolla LE Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Caution: Wear gloves and a mask as a basic safety precaution to avoid inhaling or touching toxins which may be harmful to your lungs.
    • Car batteries have a voltage comparable to small Duracell batteries; don't work in fear of being shocked.
    • Open the hood and locate your battery.
  2. 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the brace securing the battery.
  3. 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the connector on the right with no coloring or cap.
    • Remove the vertically facing screw to disconnect the battery.
    • Loosen the clamp on the side directly connected to the battery.
    • Move both away from the battery once they've been disconnected/loosened enough to disconnect.
  4. 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the red cap on the second connector follow the same process you did with the right.
    • Remove the vertical screw first.
    • Loosen the horizontal screw on the side in order to fully free the battery.
  5. 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Car batteries are quite heavy so get ready to give a good lift.
    • Ensure you have a good grip on both ends and pull up both sides at once; you don't want the battery to tilt to one side
  6. 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2018 Toyota Corolla LE Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the tray that was holding the battery.
    • Clean off any dust or corrosion formed from use.
    • Place it back using the points on it to indicate how to fit it back in.
Moses Pa
crwdns2935283:009/19/23crwdne2935283:0
139 crwdns2915208:0crwdne2915208:0
California State University Bakersfield, Team 74-23, Chiang Fall 2023 crwdns2935289:0California State University Bakersfield, Team 74-23, Chiang Fall 2023crwdne2935289:0
CSUB-CHIANG-F23S74G23
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 1,774
