2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement
  1. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement, Gasket Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop the hood and remove the plastic battery cover.
  2. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a 1/4 inch flex head ratchet and a 1/4 inch shallow 10mm socket, loosen the battery cable tightening nut.
  3. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the vacuum line from the front of the intake by gently pulling up on the line releasing it from the clamps.
  4. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the MAP sensor.
  5. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a 1/4 inch 7mm deep socket and 1/4 inch flex head wrench, loosen the worm clamp on the cold air intercooler pipe.
  6. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a 1/4 inch 10mm wobbly socket, 1/4 inch 8 inch extension, and 1/4 inch ratchet, remove all 5 of the cap screws holding the intake to the cylinder head.
  7. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the intake out of the engine bay by lifting and pulling the intake towards you.
  8. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug both left and right engine ground strap connections.
  9. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a 1/4 inch 8mm deep socket, remove the 8 PCV plate mounting bolts.
  10. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the PCV plate and the old PCV plate gasket.
  11. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wipe down the mounting surface and the inside of the PCV plate with a shop rag.
  12. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new PCV plate gasket.
  13. 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2018 Ford Focus ST Positive Crankcase Ventilation Plate Gasket Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinstall the PCV plate on the side of the engine block.
    • Torque the PCV plate mounting bolts to 89 inch pounds.
Ryen Pilialoha
crwdns2935283:004/09/19crwdne2935283:0
307 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S25-G5, Crane Spring 2019 crwdns2935289:0Eastern Washington University, Team S25-G5, Crane Spring 2019crwdne2935289:0
EWU-CRANE-S19S25G5
crwdns2947412:05crwdne2947412:0
Can this be the p04DB code that came up on my car??
Angelo - crwdns2934203:0crwdne2934203:0
Would this fix the code p04DB
Poignet de porte avant n'ouvre plus suite à un choc ?
BEHIRI HAMOUD - crwdns2934203:0crwdne2934203:0
Le moteur du gicleurs d'essuie glace ne fonctionne plus ?
Le moteur de la voiture tremblote au ralenti et accélère un peu quand j'appuie sur la pédale d'embrayage
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 213
crwdns2942667:0crwdne2942667:0 8,687
