Experience the frustration of a low-key fob battery on the road? Imagine being unable to lock or unlock your car when you need to. Our comprehensive guide is the solution you've been searching for. Tailored for those unfamiliar with key fob battery replacement, this step-by-step manual not only saves you time but is a cost-effective alternative to dealership or locksmith services. Say goodbye to inconvenience and hello to hassle-free key fob maintenance!
Slide the lever on the back of the key down and pull out the emergency key from the bottom.
Using a flathead screwdriver, carefully separate the back of the key from the front by inserting it between the two shell pieces.
Locate the battery and gently pry it out of place using the flathead screwdriver.
Remove the old battery.
Take your new battery and insert it, ensuring the positive (+) side is facing up.
