This guide is your roadmap to replacing the cabin filter in a 2022 Honda Accord. The cabin filter is the unsung hero of your ride, cleaning the air that flows through your car's HVAC system. But like any hero, it can get bogged down with the grit and grime of the road - dust, pollen, you name it.
By following this guide, you'll swap out that worn-out cabin filter for a fresh one, boosting your air quality and keeping your ride smooth. This isn't rocket science - you don't need a garage full of tools, just a new cabin filter and about half an hour.
Whether you're a seasoned gearhead or just dipping your toes into DIY car maintenance, this guide has got you covered. It's straightforward, no-nonsense, and tailored specifically for the 2022 Honda Accord. Let's get your car breathing clean again.
Remove the latch by pulling it down and outward.
Simultanously pull in and toward you on both edges (preferably farthest away from you) to dislodge the dash compartment.
To remove the cap, pull the small levers simultaneously on both sides, and then pull towards you.
Remove the old cabin filter by pulling it towards you.
