2016 Nissan Altima Door Courtesy Lamp Replacement
  1. 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the door with the faulty courtesy lamp.
    • The courtesy lamp should be located on the bottom of the door.
  2. 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the lamp housing away from the door using a ESD-safe pry tool.
  3. 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press down on the white release tab at the far left end of the lamp housing.
  4. 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back on the release tab as you press down to separate the lamp housing from the door wiring.
  5. 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinsert the wire plug back into the lamp housing.
    • Gently push on the plug until you can no longer insert it further.
    • You should hear an audible click once you've inserted the plug all the way.
  6. 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn on the vehicle to verify that the new light works.
    • Look at the bulb to verify that it lights up.
    • You may have to close and re-open the door in order for the light to turn on.
    • There is a chance of electric shock if the wires to your courtesy light are faulty. Avoid touching the light bulb or wires directly.
  7. 2016 Nissan Altima Door Courtesy Lamp Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the bottom latches of the lamp into the door socket.
    • Push the top of the lamp into the socket so that the lamp housing is flush with the car door.
    • Reinserting the lamp may require more force than it appears.
If you followed all of the steps correctly your courtesy door lamp should be replaced and functional!
Jay Michalek
crwdns2935283:002/23/23crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-9, Raign Spring 2023 crwdns2935289:0University of North Texas, Team 2-9, Raign Spring 2023crwdne2935289:0
UNT-RAIGN-S23S2G9
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 667
