2015-Present Nissan Maxima Headlight Bulb(s) Replacement
  1. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Open the Hood: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Open the Hood: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Open the Hood: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the hood release latch located on the lower left portion of your dashboard (near the steering wheel).
    • Fully release the hood latch by moving the yellow prop bar to the left.
  2. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Disconnect Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery connections from the terminals using the 10 mm socket wrench.
    • Ensure that the negative (black) terminal is disconnected first.
  3. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Battery Securing Clamp: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Battery Securing Clamp: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery securing clamp by removing the following bolts:
    • Three 10mm bolts
    • Ensure that the battery clamp is tightly secured to the battery during reassembly. The battery should not move when shaken.
  4. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove the Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grabbing the battery by the handle, carefully lift it out of the vehicle.
    • The battery is heavy. Use two hands to lift if needed.
    • Ensure that the battery is facing the correct direction when reinstalled. The positive terminal will be on top and the negative terminal will be on the bottom.
  5. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Plastic Covering: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Plastic Covering: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flathead screwdriver or nonmetal pry tool, gently pry up the following clips on the plastic covering:
    • 10 plastic clips
    • Each clip is made up of two pieces. Ensure that all pieces are accounted for.
  6. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Find Driver Headlight and Remove Housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Find Driver Headlight and Remove Housing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Find Driver Headlight and Remove Housing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reaching through the battery area and to the back of the driver's side headlight, find the headlight bulb.
    • Twist the bulb to remove it from the headlight housing.
    • Once free, pull the headlight and cables up to the battery area.
  7. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Disconnect Headlight Bulb: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Disconnect Headlight Bulb: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the small tab on the wire clip to disconnect the bulb.
    • The tab is located on the side opposite of the bulb.
  8. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Install New Headlight Bulb: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Install New Headlight Bulb: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install new bulb into wire clip. A click should be felt when it is properly seated.
    • Insert the bulb back into the headlight housing.
    • The bulb will be visible inside the headlight when installed correctly.
  9. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, (Passenger Side) Remove Windshield Fluid TankTank: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic clip holding the washer fluid tank in place using a flathead screwdriver or nonmetal pry tool.
    • This clip is different than those from step 5. Keep it separate from the others.
    • Once free, remove the tank from the vehicle.
    • Remove and replace the passenger side bulb using the same steps as the driver's side.
  10. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Reinstalling the Plastic Clips: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Reinstalling the Plastic Clips: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Reinstalling the Plastic Clips: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before reinserting the plastic clips for the plastic cover, they must each be separated into two pieces.
    • First, install the shorter, hollow piece into the hole until it is firmly seated.
    • Then, insert longer, solid piece into the hollow piece until it firmly snaps into place.
To complete the repair, reassemble all parts following instructions in reverse order.
Tyler Montgomery
crwdns2935283:011/17/22crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 88
crwdns2942667:0crwdne2942667:0 1,754
