2015 Dodge Charger SXT Headlight Replacement
  1. 2015 Dodge Charger SXT Headlight Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, make sure the car is turned off and placed in park.
    • Pop open your hood.
    • This model of Charger does not require a stand to hold the hood. It will automatically hold on its own.
  2. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the three screws that secure the intake filter cover.
    • Slowly loosen the screws. Loosening them too quickly may result in the screw falling into the engine compartment.
    • Grab the intake cover with both hands and gently lift upwards.
    • Place the cover safely on top of the main engine.
  3. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the air intake cover is removed, the air filter can be taken out.
  4. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the bolt using a ratchet and an 8mm socket.
    • Lift the air intake compartment up and out of the engine bay.
  5. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the intake is safely removed, you can access the headlight compartment.
    • Remove the headlight compartment cap by twisting it counterclockwise.
  6. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the headlight compartment by twisting it counterclockwise.
    • Now remove the old headlight bulb by lifting the small lever.
    • Use gloves or a rag to keep from touching old oils or burnt marks.
  7. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Connect the new headlight bulb and firmly align the bulb to the compartment.
    • Insert it back into the compartment and turn it clockwise to secure it.
    • Double check that the bulb is properly installed and connected. If it is not installed properly, you will have to remove the intake once more.
    • Use gloves or a rag. Do not touch the new headlight bulb with your fingers as it can damage it and lower its performance.
  8. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the intake compartment back in its original place. Tighten the screw with the 8mm socket used in step 4
    • Place the air filter back in its place. Align it with the intake compartment.
  9. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using both hands align the cover with the three screws holes.
    • Tighten the three screws using the Phillips screwdriver.
    • Double check that the air intake is safely secure and not loose.
  10. 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2015 Dodge Charger SXT Headlight Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power on the vehicle to ensure the headlight bulb is successfully working.
Martin Jaramillo
crwdns2935283:009/19/22crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 2-6, Cameron Fall 2022 crwdns2935289:0University of Memphis, Team 2-6, Cameron Fall 2022crwdne2935289:0
UM-CAMERON-F22S2G6
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 108
crwdns2942667:0crwdne2942667:0 4,051
