If the brake light or turn signal of your 2015-2023 sixth-generation Ford Mustang (S550) isn't working, follow this guide to replace the taillight assembly. While working on your car may seem daunting, this guide will highlight every step in replacing the taillight assembly of your 2015-2023 Ford Mustang.
Tips and Warnings
To prevent damaging your car, remember these warnings while replacing your taillight assembly:
- Do not cross-thread the 10 mm hex nuts and plastic knobs.
- Do not over-torque the 10 mm hex nuts and plastic knobs.
Locate the two knobs inside the car's trunk.
Unscrew both knobs using your hand.
Locate the highlighted plastic rivet inside the car's trunk.
Place your trim removal tool under the rivet.
Pop the rivet out using the trim removal tool.
Grab the plastic trim and move it out over the bolts sticking out.
Move the carpet with your hands so that it is above the plastic trim.
Locate the wiring harness
Unplug the wiring harness by pressing down on the securing tab and separating them.
Locate the three 10 mm hex nuts behind the carpet.
Remove the 10 mm hex nuts using a 10 mm wrench.
Pull the taillight assembly out towards the direction of your body.
Lift up on the rubber seal and pull out the wiring harness.
Route the wiring harness of the new taillight assembly into the highlighted hole.
Slide in the new taillight assembly.
To secure the taillight assembly and trim, follow steps 1 through 5 in reverse order
