This guide will take you through how to swap out the air filter in your 2013-2016 Scion Frs or Toyota gt86. Dirtry air filter can cause your car to lose power and gas milage. The dealerships recomend to replace your filter every 15,000-30,000 miles, depending on the driving conditions. It will take you about 5-10 minutes and won't require any tools.
Pull the handle located near the driver's left leg to unlock the hood.
Pull the secondary latch located to the right of the emblem.
Prop up the hood.
Locate the air filter box, which can be found to the front right of the car.
Pull the metal clips up from the top. They will pop out.
Grab the back of the box and pull it towards the top.
To pull out the air-filter, simply pull it away from the car and lift up.
Repeat the process in reverse to install the air filter.
Line up the little pins on the cover of the box with the base of the box in order to close it.
Clip the pins back in and you're done!
Now that the new filter is installed, you're good to go.
