This guide will walk you through how to replace the rear tail light assembly on your 2013-2017 Honda Accord Coupe. With a broken tail light assembly, the chances of an accident occurring or getting a traffic ticket increase significantly.
After following this guide, you will have your car road-ready again in no time. Instead of spending hundreds of dollars to have the replacement done at a repair shop, simply follow these steps to do it yourself!
Be sure to power off the ignition and engage the parking brake before beginning this repair.
Pull the trunk release lever or hold the trunk release button on the remote to open the trunk.
Remove the plastic fasteners for the trunk interior trim using the fastener removal tool.
Pull the clips out when the fastener has been loosened enough.
Remove the four 8mm bolts using the socket wrench.
Push the tail light assembly out from the inside to unclip it.
Remove each of the four connectors from the tail light assembly.
Plug the four connectors into their corresponding ports of the replacement tail light assembly.
Push the replacement tail light assembly into its original position until it clicks.
Tighten the 8mm nuts that were removed during Step 3 using the 8mm socket wrench.
Reattach the plastic fasteners that were removed from the trunk interior in Step 2.
