2013-2017 Ford Escape Schlüsselbatterie ersetzen
  1. 2013-2017 Ford Escape Schlüsselbatterie ersetzen, 2013-2017 Ford Escape Schlüsselbatterie: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Den Knopf für die Schlüsselfreigabe verschieben.
  2. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Den Metallschlüssel aus dem Gehäuse ziehen
    Push the button against the spring and use a fingernail to pry out the key.
    Dan Smith - crwdns2934203:0crwdne2934203:0
  3. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Den Metallschlüssel in die Einkerbung auf der linken Seite drücken. Der Schlüssel sollte mit dem Ford Logo nach oben zeigen
    It works better if the end of the key is placed under the square protrusion in the center area next to the hole for the key. Use the key to gently, but firmly, lever the protrusion away from the main case. You will feel it 'pop' as the back cover comes away.
  4. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2013-2017 Ford Escape Schlüsselbatterie ersetzen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Vorsichtig die Rückschale des Schlüssels abheben
  5. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2013-2017 Ford Escape Schlüsselbatterie ersetzen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Die alte Batterie mit dem Metallschlüssel herausholen
    I cannot get the back cover off
    Kitty Wolf - crwdns2934203:0crwdne2934203:0
    See my new comment above.
    Dan Smith -
    The key is too clunky to fit next to the battery to pry it out. Use the tip of a pocket knife blade or a pointed plastic spudger to get down into the pocket next the the battery and pry it out. Remember, the '+' side of a new, 2032 battery faces "down" into the case.
  6. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Die neue Batterie mit "+" nach unten und "-" nach oben einlegen.
    I like to write the current date on the battery with a Sharpie marker, so I know how long they last.
    Place the narrower end on first and 'walk' the cover sides back into the groove, moving back toward the pushbutton end.
Um den Schlüssel wieder zusammen zu setzen, einfach die Rückschale wieder auf den Schlüssel drücken.
crwdns2935229:036crwdne2935229:0
crwdns2934873:0crwdne2934873:0
en de
100%
crwdns2934883:0Paku83crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Katelyn Olkowski
crwdns2935283:002/20/18crwdne2935283:0
565 crwdns2915208:0crwdne2915208:0
University of Delaware, Team S1-G2, McGuire Spring 2018 crwdns2935289:0University of Delaware, Team S1-G2, McGuire Spring 2018crwdne2935289:0
UD-MCGUIRE-S18S1G2
crwdns2944067:016crwdne2944067:0
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - crwdns2934203:0crwdne2934203:0
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - crwdns2934203:0crwdne2934203:0
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - crwdns2934203:0crwdne2934203:0
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - crwdns2934203:0crwdne2934203:0
Easy Cheesy Lemon Squeezy! Thanks for the assist!
Joseph Kuperberg - crwdns2934203:0crwdne2934203:0
Nice tutorial! Here’s a good link if you have other Escape year models: https://fobbattery.com/vehicles/ford/esc...
Scott - crwdns2934203:0crwdne2934203:0
super easy. Clear simple guide. Took me less than a minute!
dobos_b51 - crwdns2934203:0crwdne2934203:0
That was easy! Thank you for the pictures and the easy to follow instructions!!
rocky752 - crwdns2934203:0crwdne2934203:0
Thank you so so much! I have a 2014 ford escape and at the worst time ever, it decided to alert me my fob battery was low. (C’mon life!) Worst time ever: 2 ER visits in a month and my hands are numb and tingling and difficult to use! I just completed your excellent guide and the task is DONE and I don’t have to bother my husband! I buy my button cell batts on ebay in bulk….great prices there. Thank you so much!! If I can do it with my issues, anyone can!
Tiffany Nelson - crwdns2934203:0crwdne2934203:0
I’m glad I found this help. I would not have realized to remove the metal key first. Thanks.
Cathy Hawn - crwdns2934203:0crwdne2934203:0
The photo and description in steps 3 and 4 are misleading. Prying the notch as shown breaks the back cover sub assembly (Ford logo) instead of causing the back cover sub assembly to detach from the main fob body.
I found it easier to use my fingernail to pry around the joint between the back cover sub assembly and the main body to open the fob.
Mark - crwdns2934203:0crwdne2934203:0
Once battery is replaced and the fob is closed, is there any (re)programming that needs to occur to sync the fob with the car?
Paula Haenchen - crwdns2934203:0crwdne2934203:0
For some reason I can’t get the cover to snap back together? The little “unlock button” you slide down to take apart the remote is down and won’t slide up to lock it together?
lindasscott1 - crwdns2934203:0crwdne2934203:0
Did all this and does not restart at all lights don’t go on and trunk don’t open
Vicenta - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 30
crwdns2936753:07crwdne2936753:0 249
crwdns2936753:030crwdne2936753:0 1,020
crwdns2942667:0crwdne2942667:0 168,523
