crwdns2937539:0crwdnd2937539:0crwdne2937539:0
This guide will display instructions on how to change the battery in a 2013 - 2017 Ford Escape key fob. This easy to use step by step guide can help you easily repair your key fob to continue usage. The only item required for the restoration of the fob is a replacement battery. The process is brief, taking only minutes to complete.
Slide over the key release switch on the back of the fob.
Remove the metal ignition key from the fob.
Insert the ignition key in the notch on the left with the FORD logo facing upward.
Gently remove the back cover of the key fob.
Remove the old battery using the ignition key.
Insert the new battery with “+” facing downward and the “-“ facing upward.
To reassemble your device, replace the back cover to the key fob and secure firmly.
crwdns2935229:036crwdne2935229:0
crwdns2944067:016crwdne2944067:0
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
You have to pay for the key it doesn't come with it
Excellent guide, Thanks for the details
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
