This guide will display instructions on how to change the battery in a 2013 - 2017 Ford Escape key fob. This easy to use step by step guide can help you easily repair your key fob to continue usage. The only item required for the restoration of the fob is a replacement battery. The process is brief, taking only minutes to complete.
Slide over the key release switch on the back of the fob.
Remove the metal ignition key from the fob.
Push the button against the spring and use a fingernail to pry out the key.
Insert the ignition key in the notch on the left with the FORD logo facing upward.
It works better if the end of the key is placed under the square protrusion in the center area next to the hole for the key. Use the key to gently, but firmly, lever the protrusion away from the main case. You will feel it 'pop' as the back cover comes away.
Gently remove the back cover of the key fob.
Remove the old battery using the ignition key.
I cannot get the back cover off
See my new comment above.
The key is too clunky to fit next to the battery to pry it out. Use the tip of a pocket knife blade or a pointed plastic spudger to get down into the pocket next the the battery and pry it out. Remember, the '+' side of a new, 2032 battery faces "down" into the case.
Insert the new battery with “+” facing downward and the “-“ facing upward.
I like to write the current date on the battery with a Sharpie marker, so I know how long they last.
Place the narrower end on first and 'walk' the cover sides back into the groove, moving back toward the pushbutton end.
To reassemble your device, replace the back cover to the key fob and secure firmly.
crwdns2935229:036crwdne2935229:0
crwdns2944067:016crwdne2944067:0
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
You have to pay for the key it doesn't come with it
Excellent guide, Thanks for the details
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
Easy Cheesy Lemon Squeezy! Thanks for the assist!
Nice tutorial! Here’s a good link if you have other Escape year models: https://fobbattery.com/vehicles/ford/esc...
super easy. Clear simple guide. Took me less than a minute!
That was easy! Thank you for the pictures and the easy to follow instructions!!
Thank you so so much! I have a 2014 ford escape and at the worst time ever, it decided to alert me my fob battery was low. (C’mon life!) Worst time ever: 2 ER visits in a month and my hands are numb and tingling and difficult to use! I just completed your excellent guide and the task is DONE and I don’t have to bother my husband! I buy my button cell batts on ebay in bulk….great prices there. Thank you so much!! If I can do it with my issues, anyone can!
I’m glad I found this help. I would not have realized to remove the metal key first. Thanks.
The photo and description in steps 3 and 4 are misleading. Prying the notch as shown breaks the back cover sub assembly (Ford logo) instead of causing the back cover sub assembly to detach from the main fob body.
I found it easier to use my fingernail to pry around the joint between the back cover sub assembly and the main body to open the fob.
Once battery is replaced and the fob is closed, is there any (re)programming that needs to occur to sync the fob with the car?
Easy Peasy, Thank you!
For some reason I can’t get the cover to snap back together? The little “unlock button” you slide down to take apart the remote is down and won’t slide up to lock it together?
Did all this and does not restart at all lights don’t go on and trunk don’t open
