After about every 12,000 to 15,000 miles the air filter should be replaced because there will be a buildup of things like leaves and dust. This build up blocks the air filter from functioning properly and needs to get replaced.
Unlatch the hood by pulling on the hood release lever.
Open the hood by pushing left on the hood latch.
Remove the two 2 inch screws from the case using the Phillips #2 screwdriver.
Pull the air filter towards you to take out the air filter.
Take out the old air filter by flipping it over and pushing it out through the bottom.
Clean out any extra debris that maybe in the air filter holder or inside the engine.
