2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement
  1. 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement, Blow-Off Valve: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement, Blow-Off Valve: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the vehicle is turned off before you start.
    • Pop the hood open using the latch inside the car.
    • Press on the latch under the hood to expose the engine.
    • Allow the engine to cool completely to avoid burns.
  2. 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The blowoff valve (BOV) is located near the turbocharger on the passenger side of the engine bay.
    • Remove the three bolts connecting the BOV to the Turbo using a 5 mm Allen wrench.
    • Carefully disconnect the old BOV and inspect the hoses and flange for any debris or damage.
    • Keep the tubing connected to the old valve; this will make it easier to remove.
  3. 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the BOV's hose to the BOV solenoid.
    • Use the pliers to loosen the clamps and disconnect the hose from the solenoid gently.
    • It is normal to hear a hiss. This is just excess air being released.
    • Use the pliers to looser the clamps on the BOV and disconnect the hose gently.
  4. 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pliers, reattach the hoses to the new BOV, ensuring they are securely clamped. Tighten all clamps to prevent leaks.
    • Use the hose as a guide to lower the new BOV into position.
    • Lower the replacement BOV with the hose and align it with the mounting flange.
    • Tighten the mounting bolts removed earlier using a 5mm Allen wrench.
  5. 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2012 Hyundai Genesis Coupe 2.0T Blow-Off Valve Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the hose to the BOV solenoid.
    • Guide the clamp down using the pliers.
    • The new BOV should now be fully functional.
    • Start the car and rev the engine gently. The new BOV should release excess pressure with a clear “whoosh” sound.
Take the vehicle for a short test drive to ensure proper operation under load.
Alan
crwdns2935283:010/24/24crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 3-90, Harris Fall 2024 crwdns2935289:0CSU Los Angeles, Team 3-90, Harris Fall 2024crwdne2935289:0
CSULA-HARRIS-F24S3G90
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 249
