This guide will show you how to change a worn out headlight bulb for a 2012 Ford Fusion as quickly as possible
Locate the hood latch and pull it to open
The front hood will open and be caught by a saftey latch. Run fingers under the hood and push the latch to the left to open the hood completely
Hold up the hood with the hood support rod
Remove negative terminal from the battery using a 10mm socket. Remove the bolt that is holding the negative terminal and pull terminal off the battery.
Locate the headlight bulb in the front of the car under the hood and twist off the cap covering the headlight bulb
twist the housing to the light bulb and pull it out
unclip the light bulb from the housing latch and replace light bulb
To reassemble your headlight, follow these instructions in reverse order.
crwdns2947412:05crwdne2947412:0
What about the left side?
So this was completely useless. You only showed the one semi easy to reach bulb whereas the rest look like the front of the car needs to be disassembled to reach. Why even post this useless junk?
I agree with both previous comments. your efforts are INCOMPLETE.
What about the left side(PASSENGER SIDE THAT IS)
You only showed the one semi easy to reach(DRIVER’S SIDE, THAT IS)
Yea this guide is incomplete and not helpful.
what years do the head lite assy match with on 2012 ford fusion sle
