Use this guide to allow you to replace the windshield wiper blades on a 2015 Honda Civic. This also applies to all 9th-generation Civic models from 2012–2015. Windshield wiper blades remove rain, snow, and other types of debris from the windshield in order to provide clear visibility to the driver. They are made of a material that will eventually wear down over time, causing them to streak, squeak, skip, or just not clear as well as they used to. If your wipers have uneven lines, chatter against the glass, or fail to remove water very well.
Changing wiper blades is one of the least complicated maintenance tasks you can do on your car. All you need is a place to park on level ground and turn off the wipers. If your wipers are badly damaged, such as cracked, torn, or separating from their frames, handle them gingerly to prevent scratching your windshield.
This guide will walk you through removing the old wiper blades and installing new ones, restoring proper visibility and ensuring safe driving in poor weather conditions.
Carefully pull the wipers upwards, away from the windshield.
Hold and press the first lever of the wiper arm down and put the wiper arm straight.
Pull the wiper up and slide the blade off of the arm.
Once the hook of the windshield looks like it went through the wiper, pull the wiper out leaving only the hook in place.
To install the new wiper blades, slide the hook onto the top space.
Then attached the hook to the center space of the wiper.
Lastly, gently press the wiper downward listening for a "click" or other indication for the blade is locked in place.
Turn on the wipers and test the new blades to make sure they are functioning correctly.
Congratulations! You have successfully replaced the windshield wipers on your Honda Civic 2015. With this step-by-step guide, you were able to complete the process with ease and without having to spend extra money at a mechanic. Having properly functioning wipers is crucial for your safety while driving, especially during rainy and snowy weather conditions. Now that you have completed this guide, you have the knowledge and confidence to replace your wipers in the future. Remember to periodically check your wipers and replace them as needed to ensure your safety on the road. Thank you for using this guide and happy driving!
Amazing work I now understand how to fix my windshield wipers :)
