2012-2015 Honda Civic Key Battery Replacement
  1. 2012-2015 Honda Civic Key Battery Replacement, Unscrew battery cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2012-2015 Honda Civic Key Battery Replacement, Unscrew battery cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the key down so that the Honda symbol is facing upward.
    • Use a Phillips #0 screwdriver to remove one screw.
  2. 2012-2015 Honda Civic Key Battery Replacement, Pry the cover off: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2012-2015 Honda Civic Key Battery Replacement, Pry the cover off: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of your spudger into the notch in the side of the key/remote.
    • Pry the key remote apart to remove the cover.
  3. 2012-2015 Honda Civic Key Battery Replacement, Replace the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
    • Remove the battery.
    • Your key may contain either a CR1616 or CR1620 battery. In some cases, either type will work, but for the best results, replace it with the same kind of battery that originally came with your key.
    • Install your matching new battery in the same orientation as the original.
  4. 2012-2015 Honda Civic Key Battery Replacement, Reassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the two halves of the remote cover back together.
    • Press the unlock or lock buttons to make sure the remote is working.
    • Place the screw into the hole and tighten with a Phillips #0 screwdriver.
crwdns2935229:021crwdne2935229:0
monica
crwdns2935283:003/22/15crwdne2935283:0
471 crwdns2915208:0crwdne2915208:0
Baylor, Team 5-7, Williams Spring 2015 crwdns2935289:0Baylor, Team 5-7, Williams Spring 2015crwdne2935289:0
BU-WILLIAMS-S15S5G7
crwdns2947412:027crwdne2947412:0
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Harry - crwdns2934203:0crwdne2934203:0
Thanks, Harry!
Michelle Henderson -
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert - crwdns2934203:0crwdne2934203:0
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Arlen Kerbaugh - crwdns2934203:0crwdne2934203:0
Thank you very helpful!!!
inakwana waka -
crwdns2936751:024crwdne2936751:0 67
crwdns2936753:07crwdne2936753:0 412
crwdns2936753:030crwdne2936753:0 1,784
crwdns2942667:0crwdne2942667:0 396,114
