Changing the headlight bulb in your vehicle is a very easy procedure that can be done at home! These simple instructions will demonstrate just how easy it is. This guide supports the Nissan Versa Note 2012-2018. Please be advised that steps may vary depending on the specific model of your Nissan Versa (Ex. Note S, Note SV, Note SL). The removal and replacement of your headlight bulb should be done in safe and controlled environment. When handling the halogen bulb, be aware that the bulb contains high pressure gas and may break if the glass is touched or scratched. If possible, wear a clean pair gloves to avoid this problem.
Before beginning this repair, turn off the car, engage the parking brake, and disconnect the battery.
Push the lever underneath the hood to the left.
Insert the support rod into the slot.
Pull out the connector from the bulb.
Twist the plastic ring out from the bulb.
Twist the plastic ring back onto the bulb.
