This guide will teach you how to replace a windshield wiper blade on a 2012-Present Toyota Corolla. Wiper blades are constantly exposed, causing them to accumulate wear and tear over time. Using this guide, you’ll be easily able to replace your current windshield wiper blade for a new one.
Before beginning this repair, turn off the car and engage the parking brake.
Lift up the windshield wiper you're replacing.
Insert a flathead screwdriver into the locking mechanism of the wiper and gently pry it open.
Push the wiper blade downwards until it locks into place.
Angle the wiper away from you, so that the top is near you while the bottom is farther away.
Gently push the blade out of the wiper base.
Bring the new wiper blade into the wiper base from the car, aiming it so that the wiper base enters the lock hole.
Once the wiper blade is in, hold it from the bottom and push it upwards to secure the hold.
Push down the lock with force until it clicks.
Repeat for the second blade.
Your windshield wiper blade replacement is now complete!
