2011 Mitsubishi Galant Window Fuse Replacement
    • This is for safety.
    • You can do this by pulling the engine hood release lever which should be lower, to the right of the steering wheel and by the door.
    • In the middle of the front hood, pull the safety lever to release the hood. Be sure to unlatch the prop tool and support the hood with it by placing it into the hole under the hood.
    • It should be on the drivers side, close to the top right.
    • Remove the fuse box cover. Keep in mind, it will have some tabs that you should push. Then you can remove it with ease.
    • It should be a 30 Amp fuse located in position 5 of the box. You can see the fuse positions on the back of the fuse box cover you just removed or, refer to the diagram below.
    • Replace the old fuse with the new one.
    • Turn on the car to check and see if the windows can open and close again.
    • Close the fuse box. Unlatch the propping tool and then close the hood.
You will save money and not use up too much time. Now you can cruise with your windows down to your leisure.
Images obtained from owner’s manual:
https://drive.google.com/file/d/1VZkNLr5...
Roberto Martinez
crwdns2935283:003/31/20crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 625
