2011 Dodge Journey Brake Rotor Replacement
  1. 2011 Dodge Journey Brake Rotor Replacement, Chock Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Chock (forcefully wedge an object, such as a wood block, between tire and pavement) the wheel on the opposite corner of the wheel you are working on, so that the vehicle cannot roll forward or backward.
  2. 2011 Dodge Journey Brake Rotor Replacement, Loosen wheel lugnuts: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the ratchet and the 19mm socket, loosen each of the lugnuts 2-3 turns
    • When tightening lugnuts to reassemble, tighten in a star pattern with a torque wrench to 100 ft-lbs.
  3. 2011 Dodge Journey Brake Rotor Replacement, Place the car on a jack stand: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2011 Dodge Journey Brake Rotor Replacement, Place the car on a jack stand: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the hydraulic jack to lift the vehicle, place the jack stand, and lower the car so that it rests on the jack stand.
    • The bumps in the frame rail are the reinforced areas for lifting the car - lift at one of these umps circled in red, and place the jack stand at the other like in the picture.
    • You can now remove the wheel lugnuts the rest of the way and set the wheel to the side
  4. 2011 Dodge Journey Brake Rotor Replacement, Remove the caliper bolts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the open end of the 15mm wrench to hold the slide pin, and use the 13mm wrench to loosen both bolts, then completely remove the bolts
  5. 2011 Dodge Journey Brake Rotor Replacement, Remove caliper: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wiggle the caliper out and off of the pads/rotor, and place out of the way - do not let it dangle by the brake hose.
    • Use the brake spreader tool on the front or the caliper wind back tool on the rear to push the piston back into the caliper for assembly.
    • Pay close attention that the hose is not twisted when re-installing (flip caliper as necessary to remove twists). A twisted hose will overheat the brakes, causing damage and a reduction or loss of braking performance.
  6. 2011 Dodge Journey Brake Rotor Replacement, Remove brake pads: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the brake pads, being careful not to lose clips on caliper bracket.
    • The clips will need to be cleaned if reusing, and the tabs on the new brake pads will need to be lubed to allow them to easily slide in the bracket.
    • Make sure there is no lubricant on the pad or rotor surface during and after reassembly
  7. 2011 Dodge Journey Brake Rotor Replacement, Remove the caliper bracket: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the ratchet and socket (21mm for the front, 18mm for the rear), and remove the bolts holding the caliper mounting bracket. Again, it may be helpful to loosen both bolts before complete removal.
  8. 2011 Dodge Journey Brake Rotor Replacement, Inspect caliper slide pins: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the boot from the caliper bracket and slide the pin out to inspect. If there is heavy pitting or rust, you will want to replace the slide pins and bracket. Otherwise, lube with brake lubricant grease for reassembly.
  9. 2011 Dodge Journey Brake Rotor Replacement, Remove the rotor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2011 Dodge Journey Brake Rotor Replacement, Remove the rotor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A hard rap with the hammer at the location shown should dislodge the rotor from the hub. If not, try alternating hammer strikes back and forth from opposite ends of the rotor hat until the rotor breaks free.
    • If you miss the rotor and hit the wheel stud, you can damage the threads, requiring replacement of the stud.
    • Use the 3M Scotch Brite pad to clean the rust from the surface of the hub that contacts the rotor (where the wheel studs poke through the hub - see second pic), and to clean any shipping protectant from the new rotor's contact surface (the large flat outer ring surface where the brake pads contact the rotor)
To reassemble your device, follow these instructions in reverse order. Recheck wheel lugnut torque after 500 miles of driving.
crwdns2935229:013crwdne2935229:0
Daniel
crwdns2935283:010/11/14crwdne2935283:0
514 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-13, Donnelly Fall 2014 crwdns2935289:0USF Tampa, Team 1-13, Donnelly Fall 2014crwdne2935289:0
USFT-DONNELLY-F14S1G13
I was looking for the torque for both, the caliper pins screws, and the bracket screws. Any help on this? Thanks.
Luis Gonzalez - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 24,070
