2011-2013 Scion tC Car Battery Replacement
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2011-2013 Scion tC Car Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2011-2013 Scion tC Car Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Travis Michael
crwdns2935283:005/08/15crwdne2935283:0
140 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-2, Regan Spring 2015 crwdns2935289:0Cal Poly, Team 8-2, Regan Spring 2015crwdne2935289:0
CPSU-REGAN-S15S8G2
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 11,096
