If your interior map light is not working in your 3rd Gen Kia Optima (2011-2015), this guide will show you how to replace the mini LED bulb located within the map light console.
Before using this guide, make sure that the vehicle is powered off completely.
Wedge the tip of the prying tool between the lens and the console.
Gently pry the lens off of the console.
Separate the lens from the clips connecting the lens and the console.
Gently twist or pull away the bulb from the connection.
Insert the new bulb into the connection.
Reattach the lens back onto the console by clipping it back into place.
Push the lens into the console. When you hear a click, the lens has been attached properly.
