2010 Mazda 5 How to Troubleshoot Oxygen Sensor
  1. 2010 Mazda 5 How to Troubleshoot Oxygen Sensor, Fuse box check: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the fuse for the pre-heating of the oxygen sensor (in this case #37)
  2. 2010 Mazda 5 How to Troubleshoot Oxygen Sensor, Enummerate pins: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the sensor and decide on a numbering scheme. Also clean the pins to ensure this is not a connection problem
  3. 2010 Mazda 5 How to Troubleshoot Oxygen Sensor, Meassure: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check all combinations of the pins of problematic sensor. See comparison chart above (with the new replacement sensor).
    • If you do not have such a tester, a normal multimeter (resistance and capacitance) should be sufficient
    • If you would like a transistor tester, you can search Aliexpress for one. It is an amasing little device. https://www.aliexpress.com/item/10050015...
Leasson learned: probe the oxygen sensor pins if you experience problems:
  • Pin 1-2 is the pre-heating element, and should show around 5-6 Ohm (meaning that the pre-heating must be using around 60W)
  • All other combinations of pins should show a capacitance around 50 pF
There is a clear difference in the meassurements when comparing the defect part and the new replacement part.
Here are some good resources on Mazda and oxygen sensors, but remember: meassure the pins and look for signs of a defect device before you start taking tings apart
https://www.youtube.com/watch?v=jFFR4307...
https://www.youtube.com/watch?v=XC5HWd7P...
https://www.youtube.com/watch?v=fiOxH14J...
https://www.700r4transmissionhq.com/p013...
LarsWH
crwdns2935283:003/05/16crwdne2935283:0
998 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 3,159
