2010-2017 Suzuki Swift Tail Light Bulb Replacement
  1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two visible bolts.
    • After unscrewing the bolts, the other side of the light is still fastened by two clickable plugs.
    • Using the panel removal tool, pry behind each corner and unclick each plug.
  2. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, access backside of the light: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the light from the frame and place it in the trunk.
    • You might need to remove some of the cabling from cable guides.
    • You can also better see the plugs that held the light in place.
  3. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, remove the fitting: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the fitting about 45 degrees and lift it from the casing.
  4. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bulb by turning it about 45 degrees.
    • And do the reverse with the new bulb, push and turn.
    • The bulb has 2 guide pins assuring a correct install.
    • The fitting has 2 corresponding receivers.
  5. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, insert fitting: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the fitting by matching up the fitting guides with their openings on the casing and turn it 45 degrees clockwise.
  6. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, put the light back: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tuck back any cables you loosened, and place the light back on the car frame.
    • Make sure the replaced light actually works.
    • Push the light plugs back in.
    • Put the 2 screws back in.
    • You are done.
knipwim
crwdns2935283:009/01/18crwdne2935283:0
13.255 crwdns2915208:0crwdne2915208:0
crwdns2935297:039crwdne2935297:0
crwdns2936753:07crwdne2936753:0 92
crwdns2936753:030crwdne2936753:0 453
crwdns2942667:0crwdne2942667:0 41,786
