Use this guide to replace a cabin air filter in a 2009 Toyota Camry.
Cabin air filters are made of multi-fiber paper cotton that helps prevent dust, pollen, dirt, and other pollutants from entering the cabin through your A/C and heat vents. Any cabin filter can be used as long as it is for a 2009 Toyota Camry. It is recommended to change an air filter every 12,000-15,000. There is nothing harmful that can happen from replacing the filter. It is an easy fix that can be done in less than 5 minutes.
Open the glove compartment.
Unhook the damper arm connected to the glove box.
Push in the sides of the glove box in order to take it out.
Take out the filter and clean around the area where the filter goes in.
