2009 Honda Fit Brake Light Bulb Replacement
  1. 2009 Honda Fit Brake Light Bulb Replacement, Brake Light Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open your trunk to access the brake light panel.
  2. 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a trim removal tool or your key to pry the panel and gain access to the brake light.
  3. 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the brake light socket clockwise until it unlocks.
    • Pull out the brake light socket.
    • Make sure you are replacing the bottom bulb(brake light) and not the top bulb(tail light).
  4. 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the old bulb from brake light socket and insert new bulb.
    • The old bulb can be identified with its dark burnt look.
    • Wear a nitrile glove or something similar to avoid getting oils from your fingers on the glass bulb. The oils and salt on your hands can reduce the life of the bulb and cause it to burn out more quickly.
  5. 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert brake light socket with the new bulb into the housing compartment.
    • Similar to the removal, you have to rotate the socket into a locked position.
  6. 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Honda Fit Brake Light Bulb Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After reassembly, have someone test the brake light so you can see if it works or not.
    • If no one is available to help, reverse towards a wall and park. Press on the brake and look at your side mirrors to check if they light up.
mchail
crwdns2935283:003/05/24crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 8-7, Grodsky Spring 2024 crwdns2935289:0CSU Los Angeles, Team 8-7, Grodsky Spring 2024crwdne2935289:0
CSULA-GRODSKY-S24S8G7
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 1,874
