2009-2014 Ford F-150 Headlight Replacement
  1. 2009-2014 Ford F-150 Headlight Replacement, Headlight: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement, Headlight: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement, Headlight: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop the hood open.
  2. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To pop the hood, undo the latch locking it.
  3. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an adjustable wrench to disconnect the negative power from the battery (Turn counterclockwise then lift).
  4. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Note each socket placement.
  5. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Note what each socket looks like (They are 10 mm large.)
  6. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the socket wrench with the 10 mm socket to unscrew each socket (Turn counterclockwise).
  7. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the headlight housing. Don't be afraid to use some force.
  8. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note the headlight bulb location.
  9. 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009-2014 Ford F-150 Headlight Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the headlight bulb (Turn counterclockwise then lift).
After everything in this guide is done, all you need to do is take off the previous headlight bulb and put the new one in. Then, be sure to reassemble everything by following these instructions in reverse order. If for some reason this does not solve your issue, be sure to make sure everything is reconnected, including both the battery and headlight bulb. Otherwise, you may be trying to fix something that is not the issue, or only part of said issue.
crwdns2935229:05crwdne2935229:0
Alec Gasbarro
crwdns2935283:005/25/19crwdne2935283:0
329 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team S8-G22, Prince Summer 2019 crwdns2935289:0Pasco Hernando, Team S8-G22, Prince Summer 2019crwdne2935289:0
PHSC-PRINCE-SU19S8G22
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 6,784
