2009-2015 Toyota Prius Technique
  1. 2009-2015 Toyota Prius Technique, 2009-2015 Toyota Prius Technique: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the hood of the car and locate the fuse box.
  2. 2009-2015 Toyota Prius Technique: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fuse box cover, and find the emergency jump point, which is red and labeled. Remove the cover.
  3. 2009-2015 Toyota Prius Technique: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the positive clamp of your jumper cables to the jump point, in the fuse box.
  4. 2009-2015 Toyota Prius Technique: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the second red clamp to the positive terminal of the car you're using to jump-start the Prius
  5. 2009-2015 Toyota Prius Technique: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the black clamp to the negative terminal on the car being used to jump-start your car
  6. 2009-2015 Toyota Prius Technique: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009-2015 Toyota Prius Technique: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the remaining black (negative) clamp to the ground located on the left side of the Prius engine.
    • Start the engine of the second vehicle, press the gas pedal slightly, and keep that speed for around 5 minutes, to give the car a chance to recharge your dead battery.
    • While the second car is still running, turn your Prius on, making sure it's both on and a ready light is illuminated. Consult your owner's manual on how to engage the vehicle without starting the hybrid system if needed, then engage the hybrid system after the power turns on.
    • Do not turn the Prius off! Remove the jumper cables while the vehicle is running. Then, turn the second car off, and remove those cables.
    • Remember, you need to drive the car you just jump started for at least 30 minutes to give the 12V battery time to recharge. Get your battery checked right away and replace it if needed so this doesn't happen again.
That's it! I knew you could do it. Pat yourself on the back and go get your battery checked. You might know how to jump-start your car, but I'm betting you don't want to do it again any time soon.
Chaya Milchtein
crwdns2935283:007/06/23crwdne2935283:0
1,177 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 141
crwdns2942667:0crwdne2942667:0 1,396
