If you are always in the search of making your vehicle look better then you may want to start by changing your dull factory lights to some bright ones. Follow this guide if you want to replace the fog lights in your 2009-2019 Dodge Ram.
Installing bright LED lights will always be popular. This modification plainly makes your vehicle look better. Apart from looking fantastic, your lighting range during night rides changes tremendously. This is a great benefit so the driver can see very clearly at night and avoid hitting things on the road.
Pull the hood latch that is located beneath the steering column.
Push the lever to the left to unlatch the hood of the truck.
Using the ratchet and 10mm socket, disconnect the negative battery terminal by turning counterclockwise.
Using the ratchet, extension, and the 10 mm socket unscrew the three 10 mm bolts to let the mounting plate free.
Push the tabs inward and pull the mounting bracket towards you to separate the bracket from the fog lamp.
Grab the new fog lamp and insert the three clips into the three holes of the mounting bracket.
Align the three screw holes on the mounting bracket with the holes on the bumper.
Screw on the three 10 mm bolts in the holes.
Tighten the bolts using the 10 mm socket and ratchet.
Reconnect the lighting harness back up to get a power source.
Reconnect the negative battery terminal.
