2008 Toyota Corolla Battery Replacement
  1. 2008 Toyota Corolla Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2008 Toyota Corolla Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the car hood.
    • The battery will be located on the bottom right.
  2. 2008 Toyota Corolla Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2008 Toyota Corolla Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two terminals on the battery. The positive terminal is on the left with the red cover. The negative terminal is on the right.
    • Unscrew the bolt to loosen the negative terminal.
    • Remove the negative terminal from the battery.
  3. 2008 Toyota Corolla Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2008 Toyota Corolla Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the red cover off the positive terminal.
    • Unscrew the bolt to remove the positive terminal.
    • Loosening the screws of the terminal can be difficult. In the first picture, I used pliers to help loosen up the screw holding the terminal tight.
  4. 2008 Toyota Corolla Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2008 Toyota Corolla Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2008 Toyota Corolla Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery's terminals from the battery, and remove the old battery.
    • Batteries, over time, tend to get dirty. You can mix baking soda with water and use a brush to clean your terminals.
  5. 2008 Toyota Corolla Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2008 Toyota Corolla Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2008 Toyota Corolla Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once everything is clean, you can begin installing your new battery.
    • Install your new battery in the correct space. You will install the negative terminal first, then the positive terminal.
    • Before moving on, make sure each screw on the terminal is tight and secured.
  6. 2008 Toyota Corolla Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that every bolt is secured.
    • Start your car and let your car run for a couple of minutes.
Lair Noriega
crwdns2935283:004/04/22crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 4-84, Briggs Spring 2022 crwdns2935289:0CSU Los Angeles, Team 4-84, Briggs Spring 2022crwdne2935289:0
CSULA-BRIGGS-S22S4G84
Just had my Toyota 2008 model battery replaced but the battery keeps draining. But when I put it on a different car it doesn't drain but it drains on mine. What could be the problem?
Ronny Obeng - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 128
crwdns2942667:0crwdne2942667:0 6,580
