Headlights are a critical component to ensure safety on the road for both yourself and other drivers. Knowing how to replace your headlight can save you time and money if your headlight is either damaged or worn out.
(Right Side Headlight)
Turn the wheel all the way inward to have enough clearance.
Locate the inner fender's retainer clips.
Using a flat-head screwdriver, pry out the retainer clips.
Pry back the inner fender liner to gain access to the headlight bulb.
An object may be needed to keep the fender liner pulled back
Locate the headlight bulb, and turn the item clockwise so that it points towards the engine.
For the left bulb, turn the item counter clock-wise
Pull out the headlight bulb from its socket.
To disconnect the bulb, pinch the top of the white block to release it from the bulb
