Every summer a lot of people suffer from a smelly car air conditioner. This is usually caused by an old cabin air filter. Below is a step by step guide to replacing the filter of your 2007-2013 BMW X5 E70 yourself. Save your time and money instead of making an appointment with the dealership!
Pop and lift the hood by pulling the release lever below the driver's seat.
There are four plastic screws on the air filter cover.
Twist each of the plastic screws with the half inch screw driver a quarter turn counter-clockwise。
Once plastic cover has been removed, cabin air filter cover will be exposed.
There are three 1/2" plastic bolts.
Unscrew each plastic bolt by turning a quarter turn counter clockwise.
Remove the electronic plastic connector before removing air filter cover.
Remove the air filter cover from the vehicle.
Once the filter cover has been removed two air cabin filters will be exposed.
Locate the plastic clips on each end of the filter holder
Depress the clips using your thumbs to remove the air filter.
Clip the filters back into place one side at a time.
Repeat the process for the second filter.
Reinstall the filter cover.
Re-connect the plastic electronic plug.
Re-install the plastic cover.
Clean dust off the cover for good measure.
To reassemble your device follow these instructions in reverse order.
crwdns2917034:0crwdne2917034:0
This is not a cabin filter lol
E70/E71 have an actual cabin filter under the glove box.
