2006 Xserve Teardown
  1. 2006 Xserve Teardown, Unplug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug power and connections and hold power for 15s to make sure the residual power is gone
    • Careful with the fibre lines if you have a raid attached
    • Graphic card if installed
  2. 2006 Xserve Teardown, Remove Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two thumb screws at the back.
    • Pull back on the top, then remove the top cover.
  3. 2006 Xserve Teardown, Remove Power Modules: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove Power Modules: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove Power Modules: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • pull out and to the right with the black locking lever
    • Pull out module
  4. 2006 Xserve Teardown, Remove HardDrives: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove HardDrives: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove HardDrives: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push on the caddy handles to release the handle's then pull each one out.
  5. 2006 Xserve Teardown, Remove Airduct: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove Airduct: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove Airduct: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • use a #1 phillips on the 5 screws holding the Airduct in place.
    • slide up and out easily.
    • carefull with the backplane-to-logic board I/O cable
  6. 2006 Xserve Teardown, Fan Array: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Fan Array: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Fan Array: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • please note these are captive thumb screws and will not come all the way out
    • To remove the fan array you need to loosen two phillips on the right and left of the array as noted in the pic's.
    • Carefull around the fan plug requires you to pull straight up after screws are lose
  7. 2006 Xserve Teardown, Remove PCI Cards: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove PCI Cards: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Remove PCI Cards: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the two captive screws that secure the riser bracket to the back panel.
    • pull up a little to clear the captive screws then lean back should come out easy
    • the Screws in the case act like alinement pins careful when pulling up
    • Also a good time to check the ROM battery! Replace battery only with type CR2032.
  8. 2006 Xserve Teardown, Front Panel Board Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Front Panel Board Cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Front Panel Board Cable: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is a delicate cable push the 2 sides together to release
    • This cable is molded to go back in only one way do not try any other orientation
    • Pop one side out then rock the connector wile pressing on the other tab for easier removal
    • The connecter is keyed for one way only
  9. 2006 Xserve Teardown, Backplane-to-Logic Board I/O Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Backplane-to-Logic Board I/O Cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Backplane-to-Logic Board I/O Cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • they are only press in connectors use a Spudger to pry one side, should come free after a little force
    • Carefull with the connecters as they can be damaged!
    • Note! there is adhesive on the side of the cable along the power module's side
  10. 2006 Xserve Teardown, CD Drive Cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, CD Drive Cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, CD Drive Cable: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • lift one side of the connector gently it should pop out
    • !Note! more adhesive out lined in red!
    • Don't Use a screw driver like i did use a plastic Heavy-Duty Spudger
  11. 2006 Xserve Teardown, Removing CD Drive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Removing CD Drive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Removing CD Drive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock the CD locking leaver by sliding the arm to the left.
    • Push back away from bezel then lift up and out the drive.
    • Unscrew 4 #0 Phillips screws and remove carriage
  12. 2006 Xserve Teardown, Ram Removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Ram Removal: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Xserve Teardown, Ram Removal: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove open the tabs on either side of the Ram slot to remove~ repeat for all ram.
    • !note! Max Ram on a 2006 =32GB
  13. 2006 Xserve Teardown, Raid card/ Drive Array: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006 Xserve Teardown, Raid card/ Drive Array: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the one thumb screw on the main part of the board
crwdns2935229:05crwdne2935229:0
crwdns2935103:0crwdne2935103:0
mitch
crwdns2935283:007/09/16crwdne2935283:0
262 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,666
