2006 Toyota Highlander Side View Mirror Replacement
  1. 2006 Toyota Highlander Side View Mirror Replacement, Side View Mirror: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement, Side View Mirror: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement, Side View Mirror: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Heavy-Duty Spudger
    • Pop out the master switch panel with a heavy duty spudger by sliding it in from the side.
    • Flip the master switch over to see the plug.
    • Unplug the master switch panel by firmly pushing down the notch and pulling it out.
    • This may require some force.
  2. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the door handle with the spudger by sliding it in from the side. Make sure to get it into the middle as there is a notch there holding it in place.
    • Note the arrows when replacing it.
  3. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single Phillips screw hiding beneath.
  4. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the door handle area, pry the small screw cover open with a spudger.
    • Remove the single screw with a Phillips screwdriver.
  5. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the wedge between the lock and the frame to pry the frame out.
  6. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to remove mirror cap.
  7. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver (or any other sufficiently thin object) to push in the center piece. Use a spudger to remove the push cap.
  8. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Although not needed for now, push the push-cap back up to re-insert it later.
  9. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Completely remove the door panel by feeling for a gap underneath the door. Use the heavy duty spudger to pop the door panel off.
    • When putting the door panel back on, make sure the master switch panel plug from step 1 is accessible, otherwise you may need to take panel off again to reach it.
  10. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the door panel and lift it up and over to completely remove it from the door.
  11. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the door courtesy light located at the bottom of the panel.
  12. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check for plastic pins. If some are stuck do the door, use a clip to pull it out. Slide it back into the door panel for later.
  13. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the mirror's cable from the car.
  14. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove tape from the wire using scissors.
  15. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three bolts with a ratchet and a 10 mm socket.
  16. 2006 Toyota Highlander Side View Mirror Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly pull the mirror out (make sure the connected wire also comes out).
    • Place in the new mirror by doing the above bullet point in reverse.
    • Note that there is a plastic covered "leg" above the wire. You will need to line this up with it's associated hole when putting in the new mirror.
To reassemble your device, follow these instructions in reverse order. The reminder bullet points will notify you if any special actions are required for reassembly.
Anthony Ambartsoumian
crwdns2935283:002/10/23crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 546
