This guide will explain how to replace a failing throttle position sensor or TPS in a 2006 Ford Mustang with the 4.0L V6 motor. You may need to complete this repair if you have a rough idle or if the car is hesitating while accelerating. Your car may also display a check engine light. You can have an auto parts store or mechanic read the check engine code to confirm that this is in fact the issue you are having.
Pull the release lever for the hood.
Slide the latch under the center of the hood to the left and then open the hood.
Disconnect the positive battery terminal by loosening the 10 mm nut and pulling the wire of the red battery terminal.
Remove the connector attached to the TPS by sliding back the red clip and pulling.
Use a T20 Torx screwdriver to remove the two bolts holding in the sensor.
Install the new TPS and put the two T20 Torx bolts back in.
Connect the connector to the new TPS and make sure the red clip is pushed forward.
Reconnect the positive battery terminal, by tightening the 10 mm nut and putting the red cover back over it.
Close the hood and make sure it is closed securely.
Start the car and make sure that it is running normally.
