In this guide, we will replace the battery of a 2006-2011 Honda Civic key FOB. This is a fairly simple project that can be completed rather than potentially spending a minimum of $90 on a replacement.
Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
Gently lift the outer shell and remove it from the rest of the device.
Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
Unclasp the inner shell using the clips on the top and bottom.
Remove the battery inside of the inner shell of the key FOB.
Replace the old battery with a new one.
To reassemble your key FOB, follow these instructions in reverse order.
