2006-2011 Honda Civic Dome Light Replacement
  1. 2006-2011 Honda Civic Dome Light Replacement, Dome Light: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006-2011 Honda Civic Dome Light Replacement, Dome Light: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before replacing the dome light and to avoid a short circuit, disconnect the car battery first.
    • Open the hood of your car by pressing the front latch and lift the hood.
    • Carefully attach the hood strut, (located towards the left of your car's engine), into the slot to hold the weight of the hood.
    • Disconnect the positive terminal of the battery in order to avoid short circuits.
  2. 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger and insert it into the space between the dome light cover and edge.
    • Gently pry the cover off but be careful that you don't break any of the clips attaching the cover to the assembly.
  3. 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Evaluate if the bulb is just loose or if it has burned out and needs to be replaced.
    • In this case, you can see that the bulb has turned black from the inside, indicating it has shorted out. This bulb needs to be replaced.
  4. 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to detach the bulb from one end of the socket.
    • Pull the bulb out of the socket with the end that is loose.
  5. 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the new bulb with the socket and push it back into place.
    • Ensure the bulb is connected to each end of the socket or it will not function.
  6. 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before attaching the cover of the dome light, reconnect the car battery carefully and test the light to make sure it works.
    • Align the tabs on the dome light cover with the holes in the assembly and push the cover back into place.
  7. 2006-2011 Honda Civic Dome Light Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You should now have a functioning dome light.
Hashim
crwdns2935283:010/17/22crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
York University, Team B-1, Allen Fall 2022 crwdns2935289:0York University, Team B-1, Allen Fall 2022crwdne2935289:0
YORK-ALLEN-F22SBG1
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 1,022
