Is your signal light not working, and in need of replacement?
Whether it's due to the weather, A burnt signal light, or a blown fuse.
This guide of 9 easy-to-follow steps will help you locate and replace your signal light.
Please Note: This guide will only work if it's a signal bulb issue and not a wiring issue.
Pull the hood release lever towards yourself until the hood pops.
Open and move the bonnet lever towards the left to completely release the hood.
Lift the prop and place it inside bonnet hole to keep the hood open.
Turn your wheel to the appropriate side to locate the signal light.
Pry off the clip under the wheel well using a flathead screwdriver.
Remove the lining by pulling it straight back.
Twist the signal housing counter-clockwise until it releases.
With one hand grab the socket and with the other pull the bulb straight out of the socket.
