This is a guide to remove an old ignition coil and install a new one. This is standard maintenance for this vehicle and can be preformed with just a socket wrench with a ten millimeter head.
Pop the hood and remove the black plastic cover over the engine.
Unplug the ignition coil you wish to replace. The coils are numbered one though four, left to right.
Unscrew the bolt of the coil that needs to be replaced.
Pull the coil straight up and out. It should come off of the spark plug with little resistance.
Apply a pea-sized amount of grease to the new ignition coil. It should be all around the rubber tip around the bottom.
When inserting the new ignition coil, press down lightly to ensure it is completely in place.
Re-plugging in the ignition coil, and re-screw it in. This can be preformed in either order.
