In this guide we will be replacing the car battery in a 2005 Volkswagen Jetta. This is useful when the previous battery dies or is no longer working. For this model you do not need a computer update (despite what AutoZone will tell you) as the technology used for newer models is not present here. A 2005 VW Jetta will use a 47 or H5 battery (they are the same) with a minimum of 360 CCA (cold cranking amps). Something to note about this guide is that the smaller red cord attached to the positive terminal is for an amp that is hooked up and will not be present is most cars.
Before starting this repair, place your car in park, engage the parking brake, and power off the ignition.
Pull the black lever to the left of the brake pedal and then lift the latch on the very front end of the hood to open the engine bay.
Locate your car battery.
Using a socket wrench, loosen the 10mm nut on the positive (red) side of the battery.
Pull up on the positive (red) battery cable from the terminal to remove it.
Let the cable rest on the side.
Repeat steps 2 and 3 for the negative (black) side.
Remove the hard outer casing around the battery and set it aside.
Remove the soft inner casing and set it aside.
Locate the lower stability bracket on the lower left side.
Use a 13mm socket to remove the stability bracket.
Lift the handle on the battery and pull to remove it.
To reassemble your device, follow these instructions in reverse order. Your battery cables will go in between the soft inner casing and hard outer cover.
