This guide will show you how to replace the faulty liftgate latch/back lock sub-assembly and how to open a stuck trunk door for a 2005 Toyota Sequoia.
The Toyota Sequoia has a well-known fault that results in the trunk door remaining locked or unable to close properly. This can either make accessing the trunk more difficult or may potentially cause a hazardous situation where the trunk opens while driving. This is because the liftgate latch may have gotten jammed or cracked the fragile actuator motor it is attached to.
Open the trunk door if you are able to do so.
Pull upwards on the plastic covering the trunk strap to remove it.
Using a Phillips screwdriver, remove the screw holding the trunk strap.
Use a plastic trim kit to start removing the trim on the trunk door.
Use a 10 mm socket wrench or ratchet and remove the 8 screws located on the edge of the metal trunk cover.
Use a spudger to partially pry open the plastic discs holding the metal trunk cover and push the trunk cover off the discs.
Use a flashlight to follow the black cable that leads to a plastic covering which hides door latch cable.
Use your fingers to pull down on the plastic covering and remove it.
Use your hand to pull the cable downwards to release the bottom half of the cable.
Push the cable towards the metal ball and push downwards to release the cable fully.
Use a spudger to pry open the plastic holder and take the cable halfway out.
Use a spudger to pry off the plastic covering the trunk latch.
Use a 10mm socket wrench or ratchet to remove the three screws.
Push upwards and in on the trunk latch.
Using your fingers or a spudger, squeeze both sides and push in.
Use a flashlight and your hands to squeeze to remove white plastic plug connected to the trunk latch.
Using your hands, slide the trunk latch to the right side of the trunk and remove.
Use a spudger or your hands to squeeze and remove the black plug.
Use a Phillips screwdriver to remove the two screws holding the plastic trunk latch cover.
Use your hands to pull downwards on the black cable to expose more of the trunk latch from the plastic covering.
Remove the plastic covering by pulling it clockwise from the trunk latch.
Use a Phillips screwdriver to remove the two screws holding the actuator motor to the trunk latch.
You can now reuse or replace your old actuator motor and attach it to a new liftgate latch.
