2005 Mustang GT Serpentine Belt Tensioner Replacement
  1. 2005 Mustang GT Serpentine Belt Tensioner Replacement, Serpentine Belt Tensioner: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To open the hood, pull the hood latch located on the left side of the driver's foot well.
  2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push a lever (located just above the horse in the grill) to the left.
    • Lift the hood up, pull the prop out, and insert it into the hole on the hood labeled "prop."
  3. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery using an 8 mm socket and 3/8 inch drive ratchet.
  4. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the band clamp on the throttle body with a flathead screwdriver.
  5. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the band clamp on the air filter or airbox.
  6. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the intake tube back and to the left to remove it from the throttle body and airbox.
    • Place the intake tube out of the way
  7. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make note of the orientation that the serpentine belt runs. If the tensioner is broken, and the belt is no longer on, refer to a diagram for the vehicle. If still attached, release tension on the belt using a 1/2 inch breaker bar turned in the clockwise direction and remove it.
  8. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 10 mm bolts with your 3/8 drive and 10 mm socket.
    • Remove the tensioner.
  9. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new tensioner and torque the bolts to 20ft lbs. then using the breaker bar turn clockwise to allow the reinstallation of the belt.
    • Using the breaker bar, turn clockwise to allow the reinstallation of the belt.
  10. 2005 Mustang GT Serpentine Belt Tensioner Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure all the grooves of the pullies are seated in the belt correctly, then release the tensioner to seat the belt.
Patrick Hall
crwdns2935283:003/22/21crwdne2935283:0
202 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G9, Sinclaire Spring 2021 crwdns2935289:0UMass Dartmouth, Team S1-G9, Sinclaire Spring 2021crwdne2935289:0
UMASSD-SINCLAIRE-S21S1G9
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 3,145
