2005 Buick LeSabre Headlight Replacement
  1. 2005 Buick LeSabre Headlight Replacement, Headlight: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2005 Buick LeSabre Headlight Replacement, Headlight: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the hood release lever to unlock the hood.
    • The lever is under the dashboard, next to the emergency brake pedal.
  2. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the hood latch lever located underneath the hood, above the Buick crest up.
    • Lift the hood all the way up and secure it in place.
  3. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the headlight housing.
  4. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of pliers or an 11 mm socket wrench to remove both headlight housing bolts.
    • Keep the bolts for reassembly.
  5. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the housing by gently pulling it out toward the front of the car.
    • Once the housing has been moved, find the headlight terminal on the back of the housing.
    • This is the high-power headlight. If you are replacing a regular headlight, you will find it situated further toward the side of the car on the back of the housing.
    • Potential for device damage: If the housing is pulled too far, it can fall out of the car, possibly severing the headlight wires. Therefore, be careful to support the housing while performing the repair.
  6. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the quick snap power conduit by pulling up and back on the two retention tabs.
    • Rotate the headlight counterclockwise to loosen it.
    • Disconnect the cable.
  7. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old headlight by pulling it straight out.
    • Replace it with the new headlight bulb.
    • Avoid touching the light bulb, as the oil and salts on your hands can create a hotspot, potentially causing the bulb to burn out sooner than usual.
  8. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tighten the headlight by turning it clockwise until it stops.
    • Push the quick snap power conduit back into the headlight socket to reattach.
  9. 2005 Buick LeSabre Headlight Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2005 Buick LeSabre Headlight Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the headlight housing back into place.
    • Replace the headlight housing bolts and tighten them using an 11 mm socket wrench.
    • Congratulations, the repair is complete!
Evan Roberts
crwdns2935283:003/03/24crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 52-10, Watkins Winter 2024 crwdns2935289:0Austin Community College, Team 52-10, Watkins Winter 2024crwdne2935289:0
AUSTINCC-WATKINS-W24S52G10
Thanks this is what I am doing tonight on my 03 Buick LeSabre. Perfect timing? 😊
Deb🐳 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 289
