2004 Lexus 330 RX Battery Replacement
  1. 2004 Lexus 330 RX Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up the lever underneath the steering wheel to pop up the hood.
    • Unlatch the hood.
    • The battery should be located on the lower right side of engine.
  2. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a wrench with a 10 mm socket to remove the bolts of the bracket.
    • Repeat the step above for the second bolt.
  3. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metal rod on top of the battery.
    • The second and third pictures were taken without the battery for a better view of the rod.
  4. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bolts on the clamps with a 10 mm socket.
    • Repeat the process on the second terminal of the battery.
  5. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the clamps from the terminal.
    • Sometimes clamps are stuck in place due to corrosion or battery leak. Use caution while removing it.
  6. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the battery from the engine.
    • Do not tilt the battery while removing it.
  7. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the new battery in the engine.
    • Place the metal rod back in place.
  8. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the bracket back on top of the battery.
    • Use a wrench with a 10 mm socket to secure the bolts of the bracket.
    • Repeat the above step for the second bolt.
  9. 2004 Lexus 330 RX Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2004 Lexus 330 RX Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the terminal back on.
    • Put the bolts on the clamps back on with a 10 mm socket.
    • Repeat the previous step for the second bolt.
You have successfully changed the battery of Lexus 330 RX 200. Good Job!
crwdns2935229:05crwdne2935229:0
Sahil Ghate
crwdns2935283:002/03/20crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S9-G5, Pinholster Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S9-G5, Pinholster Spring 2020crwdne2935289:0
ERAU-PINHOLSTER-S20S9G5
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 4,441
