This is a quick 6 step guide to replace the tail light on a 2004-2008 Ford F-150. This guide shows the replacement of the passenger side tail light, but the driver's side does follow the same procedure. This repair does not require any background knowledge or contain any serious hazards.
Park the vehicle on a level surface.
Turn the vehicle off.
Use the 8mm socket wrench to remove both of the mounting bolts.
Remove the tail light by pulling the tail light housing straight back, away from the vehicle.
Twist the upper socket counter clockwise.
Pull back to remove the socket from the tail light assembly.
