The air filter in your vehicle plays a crucial role in maintaining its performance and fuel efficiency. In this project, we'll be using a Microgard MGA46503 engine air filter to ensure that your 2003 Chevrolet Cavalier's engine breathes clean, filtered air. With a wide range of choices available for air filters, making the right selection is essential for the health of your vehicle. In this guide, we will explore the steps and benefits of replacing your air filter, helping you keep your car running smoothly. Let's dive into the world of DIY car maintenance and discover how you can easily enhance your Chevy Cavalier's performance.
Pull the hood release lever.
Pull up on the hood slightly and lift the safety latch.
Open the hood and hold it with one hand.
Grab the prop rod in the other hand.
Insert the prop rod into one of the slots in the hood to secure it in place.
Unclip the wiring harness from the retaining clamps with a flathead screwdriver.
Pull the wiring harness out of the clamps.
Unscrew the four cover-mounting screws holding the air filter cover on.
Separate the housing halves to access the air filter element.
Remove the old air filter.
Place the new filter in the housing.
